Hi all, I hope I can gain your collective insight on this...
We are looking at a property which is part of an old manor house now split into eight separate dwellings. When it was converted in 1986 a large extension with a flat roof was added to the rear. Part of this covers the ground floor of the property we would be buying and the rest covers 8 small single garages belonging to the other residents. I'd estimate the surface area of this flat roof to be between 150 and 200 m2.
If we buy this place we would be planning on replacing the roof covering, probably with epdm ( currently felt, not sure how old). I'm not sure how the current roof was constructed, I'm assuming cold roof if it was mid to late 80s?
However my concern is that it hasn't been well ventilated, if so should I expect the rafters to be shot by now? I'd worked out it should cost around 8k for materials to reboard, add insulation (not sure what building regulations were like in 1986 so no idea how it might already be insulated) and cover with epdm. I'm guessing it's a job two roofers could do in a week, say a day rate of about £200, that should come out about 10k. Would you say I'm in the right ball park?
Anyway, my main point was how much would it be likely to cost extra if the rafters are rotten? If a joiner came in would it necessitate removal of all the interior ceilings or is there a clever way to replace the rafters without ripping out all the ceilings?
Sorry, it's a bit of a long winded one but I'm trying to get as clear an idea as I can of how this could pan out.
Thanks in advance for your thoughts.
