Wondering what could be the problem with my radiators.
They are downstairs and so I doubt there would be an airlock.
When I open the bleed valve on the top (with the inlet and outlet valves closed ) there is a good influx of hot water when I open one of the valves.
When I close that valve and open the other ,there is a good influx of cold water (from the other direction now) that comes out of the open bleed valve.
But when I close the bleed valve (maybe not a "valve";it is a small round screw that goes into to top of the radiator) and open both inlet and outlet valves the radiator does not heat up.
Any ideas ? Could there be a blockage in the pipes? A blockage in the radiator even though it accepts water from either direction?
