- Joined
- 28 Dec 2016
- Messages
- 117
- Reaction score
- 4
- Country
A while ago we had a BT/Openreach guy investigate why the internet kept dropping out. Some time later I found that none of the phone extensions worked. At the time did not worry me as we use a cordless setup. Now as we are doung this and that to the property I thought I would re- instate the extensions, easier said than done. The BT guy replaced whatever box was on the wall woth a new 5C master socket. I have managed to get most extensions going but am a bit confused about the wiring in the property.
The 5C unit is connected as such A white/green and B green/white
This was how I found it yesterday with no other connections, ie the outgoing cable just dangling in the box.
Looking on the internet I wired up the outgoing cable as follows
2 blue/white 3 orange/white and 5 white/blue
Now here is the odd part. This outgoing cable disappears into a wall and have managed to access it in a ceiling void. Originally this cable looped into and out of a phone socket. As the kitchen is being gutted I have just connected the cables together. All the extensions work but only if I connect all 6 wires, just connected the blue/white, orange/white and the white/blue
result in nothing.
How does this work? I have 3 wires leaving the 5C box but I need all 6 connected further down the line.
And finally there was an extension connected via a 2 way splitter using the phone outlet socket on the 5C box. This was fed using a 4 wire cable. I cannot get this to work by wiring directly to the 3 wire setup.
result in nothing.
