a thin layer of plaster is coming off when painting.
31 Mar 2006
hi there,
i've stripped the bathroom of its old wallpaper, fixed a few holes etc.
the walls are a bit uneven and messy but i can live with a few cracks and bumps. i went over the worse bits with a sander.
i started painting with a roller just now and when i reached one section a thin layer of plaster started coming away on the roller. this broke into small pieces and then spread out a bit.
so i guess the previous owners applied a thin layer of plaster to cover cracks and now it's kind of flaking off.
i've stopped and cleaned the roller, but what do i do now?
i guess i have to wait till the paints dry then try and get the broken plaster bits off.
has anyone got any tips for getting the wall suitable for painting?
cheers
It's a pain when that happens but very common. Best bet is to water the paint down a great deal to reduce the suction. When it is stable you can apply a finish coat.
Paint the walls with some watered down PVA adhesive prior to trying to paint them ,this should do the trick. ,
Don't do this. The paint won't stick to PVA and will peel off.
Never had a problem with paint not sticking when the walls have had PVA on them in fact the total opposite. The emulsion becomes extremely durable and easy to overpaint.
I have found watereddown emulsion leads to repaint problems in the future. The emulsion peels, crazes and also wipes off with a damp cloth just what you want in a bathroom. I am sure most people with new build houses will find this to be a problem next time they come to decorate mainly due to the method you suggested being used by the contactors .
You are wrong. That's all there is to it.
Many ways to skin a cat.
Never ever had a single issue with emulsion not adhereing after coating with a light coat of watered down PVA.
I used Evo Stick wood glue in my bathroom due to peeling and flakyplaster like the original poster described , 2 years later and it still looks as good as the day I painted it.
You were just lucky. PVA and paint don't get along.
