I'm going to be using quite a lot of expanding foam (to fill in around my window frames as I take the wood trim off as I decorate...)
Been thinking about buying a foam gun... just wondering if they are worth it for a DIYer...and have a couple of questions.
Is it cheaper if you have to buy a few applicator cans (especially because the can applicator ones are cheaper than they used to be)?
Can you use the gun for other things -seen something where they seem to use the same gun for silicone etc - and if you can- do you need to buy special silicone etc?
For the foam do you really need to clean it out completely after each use? Or would it be ok for a few days? And does that not significantly increase the costs ?
Once a can of foam is opened how long will it still be usable? (Hate the can applicators - always end up with a half empty can that won't work again next time I need some! - although I have just managed to use one of the bent back applicator ones opened a year ago...but did have to dig out the set stuff from the applicator...)
Are the guns really less messy than the can applicators ?
Finally are the cheaper ones any use or do you need to spend the few extra quid (like £20) to get better ones...
Any advice/info appreciated....
