I'm about to have a daikin wall mounted split AC unit fitted to the house, the outside unit that requires the main power supply (it then supplies the indoor unit) is planned to be connected to the garage ring main circuit.
This in itself is not an issue, or dificult.... however, the AC unit is an inverter type and capable of heating fuctions as well, now, as i understand it there is a small/slim possibility that due to the way the inverter units work, it may trip the RCD in the main supply line.
The manufacturers guidence is that the units should not be connected through an RCD for this reason, however as the house wiring is old, the RCD that is fitted is an "after thought" and fitted in the line after the meter before the consumer unit, so there is no easy way to wire the unit in before this (its also seperated by about 40 odd feet !)
ok, thats the info, now.... is there any small mains conditioner/filter that i can use (consumer unit rail fitting would be ideal) to filter the mains and ensure nothing is fed back onto the ring main that could cause the RCD to trip ??
thanks for any help/suggestions
