Accenta 8 mini alarm not activating in power cut
3 Jan 2011
Birmingham
Hi there everyone. I have a Accenta 8 mini system, when we have the odd power cut the the alarm does not activate as it should. Anyone know why this is, it used to before until i changed the internal 12v battery. The alarm itself works fine. :D Even if i hold down the tamper button and remove the cable to the internal 12v battery the alarm will not go off, which i believe it should do.
Your alarm should NOT go off in a power cut unless your BACK up battery is faulty that's what it's there for!
Wow, never seen the question asked in this way before, it's usually the other way around!
