My sister has recently moved in to a new house and was given the alarm code. The code does look correct as the numbers included in the code are the most worn on the keypad. I have tried however to set it by entering the code and nothing happens. I've also tried to enter the default engineer code (9999) and go in to reset the code which seemed to go through ok, but when I enter the code code it still doesn't set
Is there a way to reset the system to factory defaults?
