Accenta+ Beeping Every Few Seconds From Panel
31 Dec 2013
Cheshire
hi guys,
losing the will to live a bit with this now!
i have a honeywell Accenta+ house alarm and haven't used it for a couple of years. Recently it has started to beep or click from the control panel every 2-3 seconds (24/7!)
i assumed it was the battery and as such bought a new one today and replaced it... however now i cannot re-connect the battery without (i assume) the tamper alarm going off, i tried entering my code for the alarm whilst it was going off (as the control panel is unresponsive until i plug the battery back in) but to no avail!
currently i have the backup battery unplugged, the alarm is still clicking every other second and the control panel only has the power light lit with control panel being unresponsive until i plug the battery in which then sets off the panel alarm.
help please :)
Best bet open panel remove bell trip wire B keypad comms and sound wire and speaker wire if fitted sound like it's seen its day . 0123 is the default code try that first.
thanks for the prompt reply!
i have took out the first wire (a white one) but when i try to take out the ones connected to the panel speaker (also white ones) it trips the external alarm?
maybe i am doing something wrong?
Google accenta eng manual .... You will see a pcb diagram only remove B and one of the ls or speaker wires, it may not even have a speaker connected , it's between the power for the detectors and strobe terminals, the keypad connectors are on the left side of pcb.
