accenta g3
11 Dec 2008
Can an Accenta G3 panel be defaulted to remove enginneers code the samE as G4 shorting out the terminal "set" and "tamp"
Carlos
You can do it but not the same way as the g4. to default the g3 you power the system down . then power the system up and press reset twice.
However if you are doing this you need to reprogram the whole system again to suit your needs. so you will need a engineer book . default customer code will now be 0123. so you can stop the noise.
