Hi all
Im new here and a telecoms engineer, ive installed the above system and am having the following 2 problems so need some help please.
I have done a Walk test and all zones activate ok, bell test and strobe test activate ok when tested from panel. Tamper activates ok if panel is opened or PIR opened.
I have set
program 1 as follows
zone 1 entry / exit and timed
zone 2 to 5 set to intruder.
When set this way and indicating as set if I trip any of the zones either PIRs or Front and Back doors the system does not set the alarm off but when un setting the tripped zone appears as activated and is cleared with user restore once entering the user code to deactivate, so i don't understand why the sounder does'nt go off internal from the LCD speaker or external from the bell box or strobe.
Issue 2.
program 2 i want to use for part set as follows
zone 5 is landing PIR and needs to be inactive all other zones need to be set.
If i try to do a part set the user manual states enter user code
press P tones stop
press 2
and system will set in part set mode.
now when pressing P after user code the tones do not stop and system sets as program 1
Think i may have wired the motion sensors incorrectly see below?
PIRs are Next K9-85 and are wired at the PIR as follows
PIR Tamper is Red and Black - Panel all red and blacks are wired together except for the PIRs as these are wired in series to a connector block with the first red and last black connected in the tamper circuit.
PIR Alarm or NC is Blue and Yellow - Panel blue and yellows are wired into one of the zones 3 to 5.
PIR 12V Green + White - Panel greens wired together connect to +12v whites wired together connected to - 0v
Dave
I have set
Issue 2.
press P tones stop
press 2
Dave
