Accenta/optima G4
12 Oct 2008
Northern Territory
Got a Accenta/Optima G4 kit from screwfix.
I am wiring up the honeywell door contacts and need to wire 2 sensors to one circuit - 2 doors on my garage.
Is the zones normally open or normally closed?
I am unsure of how to wire them in series or parallel? And would I use EOL on the contacts?
door contacts are normaly closed, so they should be wired in series
as for if you use resistors or not wha do the panel instructions say?
