Hi all,
Please bear with me because I am not a tradesman and so don't know the correct terminology!
I own a 1890's victoria stone terrace which has had an attic conversion at some point before I purchased the property.
As part of the conversion, they have installed small doors to access the remaining loft space up to the exterior house walls. Unfortunately, this door is only about 350mm wide (see attached pic).
What I would like to do is make this door wider to allow better access and board the space out for storage.
The reason the door is so narrow is because at about 350mm intervals there are vertical wooden battons that support the main structural timber for the house. The existing door fits snugly between two of these battons. What I would like to know is would it be safe to remove one of these vertical battons and effectively double the width of the door?
I hope I have explained myself sufficiently and that the pictures help.
Thank you!
Thank you!
