Bit of a mouthful that title!!
Amongst other things, I'm a bit confused regarding acclimatising solid oak 18mmx120mm.
I have 4 days and nights for the wood to acclimatise before blind nailing it.
Should I turn off the radiator in the room at first then turn it on after a couple of days to allow the wood to be gradually brought up to the room's radiator-heated temperature? (although some of the floor will be laid in front of an open fire which will be hotter)
Should I remove the plastic packaging to enable the wood to reach an equilibrium humidity level?
Any advice appreciated, many thanks.
