Ferroli Sigma gas boiler
ACL Lifestyle 679H340-30L0 3 port
Horstmann ChannelPlus H27XL Series 2 programmer
Satchwell (Sunvic) room thermostat
CWS tank and header tank with bases at same level
I am a novice at HW and CH but learning a lot thanks to this forum. Have searched all the threads to do with the Lifestyle valve but could someone tell me the purpose of the black plastic tab at the top of the unit. My unit is installed upside down on a vertical pipe but close to the floor and I can’t see anything much. Sometimes this tab is pulled tight against the unit and other times it hangs down a bit and is loose.
The HW is ok but the CH occasionally either doesn’t come on when it should or else comes on when not demanded. Usually happens after CH has not been needed for a period. Boiler, programmer and thermostat are working ok so I’m thinking it must be the valve at fault.
Thanks in advance for any info.
