We have a problem with noisy neighbours - shift workers coming and going at all hours (engines running, doors banging, and one car with a loud exhaust). The exhaust is particularly bad as it's not only noisy but reverberates through the house.
Our house already has uPVC DG from when it was built around 16 years ago. It's a cheap Redrow special as you can hear people having a conversation outside, and draughts come through the joints between the bay window sections (I once pulled off the trim and found copious amounts of expanding filler with some daylight behind it). I filled the trickle vents in our bedroom a few years ago, which helped a little.
I was wondering if replacing the windows (acoustic double glazing, triple glazing, or secondary) is likely to make much of a difference, especially given the nature of the noise - it's not your usual passing traffic. I don't want to fork out on an expensive white elephant.
