acoustic solutions tv LCD 26805
4 Jul 2012
Worcestershire
Hi.Has anyone come across this fault on a Acoustic solutions tv model number LCD 26805. The picture and sound are missing,there is a raster which is grey and has a frozen,barely discernable picture BUT I have a video recorder connected via scart lead and it plays picture and sound perfectly.Any suggestions gratefully received.
I think there are two answers to this:
1. "Take it to a repair shop".
2. "I am a professional repairer and I've come across this fault but I'm obviously not going to tell you the cause".
Armed with the circuit diagram, one could guess what part of the circuit to start testing but you'd need appropriate test equipment and knowledge. Or you could simply buy complete PCB assemblies and swap them over in the hope of finding the culprit that way.
(Unfortunately, I haven't repaired a TV since the days of valves.)
Thanks for the info.Unfortunately swopping panels would be uneconomical considering the cost of tv's now.I also was a technician with Rediffusion and Granada,and then self employed until I retired.This was before digital tvs.Also test equipment is no longer in my possession apart from an AVO.I thought if the fault was in the tuner unit it would be simple to fix,but if not it will join the other low budget TVs 'up the tip'.
If it works via the Scart socket, just buy a cheap Freeview box for £20 or less and plug in to the Scart socket.
Does the TV even have a Freeview tuner built in?
