I have had all of my radiators replaced at the same time and having done some research tried to balance the radiators because the Acova Radiators I had fitted are cold in the middle bottom and hot at the top, left and right.
Don't think its sludge because the boiler was replaced maybe a year before and there couldn't have been much water in the system once all of the old rads were removed.
There has been some improvement but the lockshield valves are nearly closed maybe one eighth of a turn open and I cant get the middle botttom section hot. The rads left, right and top are very hot.
These are very big rads and hold an awful lot more than the previous rads.
The smaller Acova rads are fine but the biggest struggle.
Is this common or do I close the lockshields even more to a dribble running through?
Also, all of the TRV's are bi directional so some are fitted to the outlet with the lockshield on the inlet. Does this matter?
Thanks in advance.
Thanks in advance.
