Activ8 AM-DT 8IR140
11 Feb 2007
Yorkshire
Just bought one off ebay...cheap to fit in in laws conservatory (as standard PIR keeps false alarming),
I have the 8IR110's in my own house and have no problems with these in my conservatory - that's what I understand about the DT's as they need both signals to alarm, hence why I got the 8IR140....
Not got home to check yet but I was sure the 110's have just one connection for the NC zone connection covering the PIR and microwave?
This appears to have 2 connections for the PIR but then there's the other 2 for the antimask connection?
So I need 8 core wire, and there's only 6 into the conservatory.
This would put the sensor over two zones?
I don't really understand but I guess these are 4 connections - 2 for the PIR, 2 for the microwave (effectively?)
any help appreciated
thanks
EDIT...bit more googling!
Understand the anti-mask now I think......(clue is in the words), so I can just not bother with the anti-mask connections, the dual tech is covered under the PIR NC connection to the zone?
EDIT 2....search function...understand it now
//www.diynot.com/diy/threads/installing-a-dual-tech-pir-with-just-6-cores.460834/#post-3665525
don't need it, also depends on what panel its being put on as to what you can do with limited cables.(resistors).
