Good Morning All,
Can i pick your brain's please; I have two outdoor lights that i want to replace with LED's.
*Lights are connected to a switch inside the house, switch isolates live at first light.
*Light one is a PIR bulkhead that has a driver inside, thus allowing for the second light to be added to the chocblock inside.
*Light two is connected to light one with the live on to a 4th cable that i suspect is power from the PIR to the lights driver (its an ancient thing) so light two comes on when the PIR triggers.
What i want to do is set it up the same way but with LEDs< i have installed the first new light but only have the obvious LN&E on the pre-terminated flex. therefore i suspect what i want to do cant be done? unless you have any wizardry ideas? the other options i suspect is get two normal none PIR lights and an external PIR? OR i try and open up the new light and see if i can connect a cable to the PIR activated live?
