hi
i want to add an external pir controlled light to my garage and also add another double socket on a different wall to save me using extension leads all the time.
the garage is new build 2.5 years old, it has power coming in from the house using its own seperate slot in the consumer unit.
i've taken some pics to show the arrangement:-
there are 2 fused switches at the door where the cable comes in to the garage. the lower isolates the power to the garage the upper is the light switch.
the cables go up in some trunking into the roof then split off, one to the central light and the other to the double socket on the garage back wall.
i've had a read of the wiki and had a search round the forum but would rather get confirmation on what i plan to do sounds ok.
for the external light can i fit a juction box on one of the roof trusses that the light supply runs along adjacent to where i want the external light, then break into the cable, wire it into the junction box and wire in another feed from the junctions box to the external pir controlled light? so it will be controlled off the pir with no switch etc.
then for the extra double socket, can i just run a spur of the existing socket up along the roof trusses like the other wiring, then down in some conduit to where i would like the new socket situated?
many thanks for your time
