So the wife has decided that she wants to wall mount a new TV on the bedroom wall, but there's no electrical sockets nearby. I'm a confident DIY'er and have previously worked on the electrics installing outdoor lighting and spurring off a socket - so I feel I can do the work that's needed.
In the corner of the bedroom is a closet, next to which the newly mounted TV will go. The plan is to put the TiVo and the CCTV DVR in the closet (both are controlled through the network so don't need remote line of sight) and pass the HDMI cables through a brush plate in the wall.
This is my CU...
The conduit at the top goes into the void space under the closet. My intention is to run cabling from the CU, up through the conduit, through the void and floor boards and up the wall to the top of the closet where I will install 2 x 2G sockets as there needs to be a socket for TV, TiVO, CCTV DVR and CCTV Camera Transformer.
So, I've done some homework and my question is... Which of the following would be the best option?
1). Add a 20A MCB to the CU. Run a RADIAL circuit in 2.5mm T+E to the top of the closet and install 2 x 2G Sockets.
2). Add a 32A MCB to the CU. Run a RING circuit in 2.5mm T+E to the top of the closet, install 2 x 2G sockets and run the cable back to the CU
3). (THIS IS THE ONE I'M LEAST SURE OF THE RULES). Run a SPUR cable in 2.5mm T+E from the existing Ring MCB in the CU to the top of the closet and install 2 x 2G Sockets.
I'm aware that there is a 4th option of extending the existing Ring Main but I fear it is unlikely that there is a suitable place to make a connection in the closet floor void. Plus, I have enough cable to go the extra 45cm direct to the CU.
Hopefully someone can tell me which is the most suitable option and whether I need to change anything to make it safe/suitable? I'm not looking for the cheapest way, I'm looking for the safest!!!
This is my CU...
