Asking this question for a friend.
Hes recently moved into a first floor flat in Aberdeen, and the flat currently has a Gas boiler but an electric cooker.
Since electric cookers are completely hopeless things, he wants to have a gas hob fitted.
Clearly there needs to be a new pipe run from the incoming gas pipe into the kitchen where the cooker resides, as this isnt currently present. This would be a straight run along one wall of about 2-3meters and would likely be a relatively cheap job and simple to have someone come and do it.
Someone has suggested to him however, that some new regulations mean that because the existing pipe feeding the boiler is only 22mm, he cannot have this T'ed into and run to the cooker. Instead he will have to replace the whole pipe run with a larger pipe. This is clearly a much bigger job, verging on the impossible.
Is this suggestion correct?
Hes had a look at the supply pipe to the boiler, and notes it reduces down to 15mm before it connects to the boiler itself, if this makes any difference?
Cheers
Kevin
Cheers
Kevin
