I want to add a new light in a cupboard within a room which I intend to connect to the main light circuit via the ceiling rose in the same room and a pull switch inside the cupboard to operate.
I'm happy with wiring this via a new ceiling rose but was thinking of just using a single downlight inside the cupboard and to save having a couple of chocblocks at the fixture is it a normal/acceptable way of wiring for me to run T+E from existing light to new pull switch, connect live in and out of this switch without cutting into the N&E then run the switched live/N&E to the new light position?
Is this an acceptable way to wire?
Cheers
Cheers
