Your advice please.
I have installed a PIR controlled security light (120w) on an outside wall as per the wiring diagram provided by FAQ (dated 5 May 2010)- "How to add a PIR with Floodlight". I have connected to the ceiling rose in the garage and have a single gang light switch for control.
Question 1. I now want to install a second PIR security light using the same feed from the ceiling rose. Is it acceptable to take a second live feed from the switch to the new light and connect the new N and E to the original with a terminal block. I appreciate that the one switch will control both lights.
Question 2. Will this work have to be certified. I am getting very confused with what I read on the forum.
Thanks for you help.
