Adding a radiator to existing system
21 Jan 2013
Yorkshire
I'm adding a radiator to an existing boiler system that was installed last year (Worcestor 30SI boiler).
I'm trying to keep the amount of flux added to the system down to a minimum by flushing out most of the new pipework, but obivously when I connect the new pipe work to the old it will then be sealed.
Do I need to flush out the system, if so with what? Just water? I have two connections on the supply and return at the lowest point in the system, so I could connect a water hose there and flush the system out with water?
Please help, thanks.
Flushing with water will be fine. Just remember to top up with inhibitor once you have completed all the work and filled the system to check for leaks.
Actually, just had a thought.
My boiler has the optional filling loop installed making it easy to add pressure (water) to the system. On the CH exit on the boiler there is a drain cock. If I can just isolate the boiler I should be able to flush the sytem using the drain cock (if I don't isolate it the water will just flow through and out the boiler).
Any ideas?
