Adding a RCD to my shower
20 Nov 2006
Essex
Currently the shower is fed from a seperate single way consumer unit with a 40amp fuse. This is then connected to the input side of the main CU.
Now I was thinking that I could just replace this consumer unit with a 40A RCD in an enclosure
Problem is the input comes in from the bottom and output is from the top. The new RCD i bought was it the other way round and there isn't enough slack in the cable to change it.
The RCD is a clipsall and doesn't mention supply/load on the terminals rather 1/N and 2/N. Anychance I could use it with the supply on the 2/N side and the load on the 1/N side?
Other optiosn i can think of are to mount upside down or connect after the shower CU just inline rather than instead of.
Cheers Jay
You can't replace an MCB with an RCD. The shower will require overcurrent protection. Perhaps you meant RCBO instead of RCD?
Most RCDs dont care which end the supply comes from. The instructions that come with it usually say this.
Why dont u wire it up the way u intend to use it and run a standard RCD test on it. If it complies with the spec you are OK.
