ADDING A ROOM OUTSIDE TO CONNECT HOUSE TO GARAGE
12 Sep 2011
HI EVERYONE
THIS IS A TOUGH ONE AND I HAVE BEEN RATTLING MY BRAIN AND PUTTING IT OFF FOR MONTHS .WE WANT TO BUILD A ROOM OUT BACK OF OUR HOUSE .PROBLEM IS ,THE ROOM WILL HAVE TO JOIN IN TO THE GARAGE ON ONE WALL ,ALSO THE CONSERVATORY SIDE ELEVATION ON THE OTHER WHICH HAS A VICTORIAN ROOF IN GLASS AND THEN EXTEND FROM REAR BACK WALL .SO I AM THINKING OF USING UPVC DOUBLE GLAZED FRENCH DOORS GOING OUT TO THE REAR GARDEN ,MY QUESTION IS HOW I SET OUT THE ROOF .I WILL TRY TO UPLOAD SOME PHOTOS SO SOMEONE CAN GIVE SOME GOOD ADVICE. WE EVENTUALLY WANT TO HAVE OUR BEDROOM UPSTAIRS (THE UPPER FRENCH DOORS WILL LEAD OUT ONTO A TWIN PLY FLAT ROOF )TO HAVE A VERANDER UPSTAIRS.
Difficult without any photos, but a simple flat roof sometimes is the best answer where roofs converge. I recently built a flat roof under two pitched roofs . It was covered in rubber, with the rubber upstands going up under the slates. The slates drain straight onto the rubber without any gutters. This flat roof then has about 1:80 fall to the garden away from the main house. A 1:80 can be walked on without the feeling of a slope.
When you annex a space like you are suggesting, the obvious choice of roof is a flattie.
However, there will always be issues regards joist/ceiling heights as the garage and connie are unlikely to be at the same height as the existing dwelling - usually a fair bit lower.
There may have to be compromises (upstands etc) that are not always aesthetically pleasing.
HI AGAIN .JUST TO SAY THAT IF YOU TAP ON MY USERNAME THERE ARE SOME PHOTOS I TOOK OF AREA IN QUESTION.REGARDS.MARK
