Hi all
I'm currently turning a spare bedroom into a music studio, and am currently working on the room acoustics....
Three of the room's walls are external, brick cavity. The fourth however is a hollow stud partition wall. I've been advised that I need to add mass to the wall (so that it is more like the other three walls) and the best way of doing that would be to add an extra layer of plasterboard.
Not knowing anything about such things, I wondered if anyone could help me out.....?
1. Is it an easy job for someone with basic DIY skills or would I need to get the pros in?
2. If the second option, what kind of price for materials and labour? The wall is 4m long and 2.2m high - but there is a door in the wall too....
3. Would the new plasterboard need to be attached to the studs only, or to the studs AND the existing plasterboard?
4. What is the thickest plasterboard I could use in this scenario? I've been advised to use X type... Is that an American thing or applicable here too?
5. As the room is upstairs, will I need to consider the additional structural load/weight? Is that likely to be an issue?
Any thoughts or help would be fantastic.
Cheers
Max
PS - hope this is the right forum.... Perhaps it can be moved if not?
Cheers
Max
