Adding a third shower - which type can I fit?
8 Feb 2006
Cornwall
I'm about to get a third shower fitted upstairs. We already have a thermostatic shower (power I think) downstairs and an electric shower in the upstairs en-suite.
The cold water tank is in the loft and would provide between 2 & 4 ft of head. There is a cold water feed already to the new shower room but only a 6ml power line. The shower room is next door to the airing cupboard which houses the hot water tank. The water is heated by an ordinary gas boiler downstairs.
I'd like to fit a power shower but have been told that it would be affected by/affect the thermostatic shower. It looks as though we'd only be able to fit a puny electric shower with the current arrangement.
Can I fit another thermostatic/power/mixer & pump shower or do I need to go for an electric sort (with consequent re-wiring)?
Many thanks in advance,
Nigel
Interal pumped shower should be OK, cold feed to be directly from tank in loft, and hot from a "flange" of some sort on the HW cylinder. You might/should have one for the existing pumped shower. You could try sharing an existing one.
Could still suck air down the vent with 2 pumps running - if the cold feed to the HW cylinder is 22mm you may need to increase that.
