Current system is combi boiler and for the central heating I have a 22mm core central heating ring (if this is the correct term). The rads are dropped of from the flow pipe and then returned to the return pipe. The boiler is in the coal shed the flow and return pipes enter the house are fed into the roof space above the basement. the basement rads and ground floor rads are connected to the 22mm pipes whist running through this roof/floor space. When the 22mm ring gets to the stairs then it is routed vertically upwards when it reaches the floor of the next level it branches out under the landing floor and the bedroom and bathroom rads are dropped of this part of the ring.
So I want to zone of the upper floor rads and the logical place to get access is to the 22mm flow and return pipes when they go upto the next floor at the stairs.
So advice required should I put a 2 way spring motorised valve on the 22mm flow pipe here and then put a towel rail in the cloakroom so there is always a flow and return open for the boiler.
Or should I put a three way valve here that when closed makes a connection between the 22mm flow and return at this point and when open allows flow upstairs.
Any advice much appreciated.
