Hi Chaps,
I've got a scantronic 9751 panel with 1 rkp.
I would like to alarm up an garage that is not attached to the property and would like to know how to go about doing so.
I would like a second rkp in the garage so that it can be set independently from the main house alarm. The alarm in the garage will just have a door contact.
If I run a cable from the garage to the panel, how do I wire it up? Does it wire straight into the keypad connection points, or is it best to do it in series? Or even parallel if possible?
In terms of programming the additional zone, will there be any problems? I have part set on C which I never use. If i take the zones off these and put the garage contact on this, would this be sufficient?
