Howdy,
Looking at adding an additional shower in main bathroom, current shower is in en suite only. Current hot water is provided by what i would call the old gravity fed system. Hot water cylinder on 1st floor where both showers are/will be. Original shower is fed by this cylinder which has a cold water tank above in the loft.
Obviously the shower is limited to the content of the cylinder and am aware both showers could not run simulateously but its an issue more of conveniance for other family members to have a shower in main bath as oppsed to coming into main bedroom.
Is it simply a matter of putting a tee on the shower supply pipe and running it to other bathroom.
It would be more conveneiant to run the new pipe up into the loft above the cylinder but below the cold water tank across about 2 meters then down into main bath to shower head.
Im working on the assumption that i will not lose any pressure as the head is measured from the shower head to the top of water in cold water tank in loft.
I will be changing to a combi boiler in a year or so but the batthroom needs doing now.
Can i do this or any thoughts.
Cheers
Stanna
Cheers
Stanna
