I am confident in wiring a new circuit as I am in many other things including wiring a light switch.
Really? Then why when you asked about something as trivial as adding a second switch to create 2-way switching did you say "I am a complete begginer at all of this and am a bit confused even though you have shown me a diagram"? Why had you not even heard of a standard domestic cable type? Why later in that thread did you say "I've decided I will rather get an electrician in than fiddle with something like this"?
If you cannot understand something as simple as adding a light switch, and decide that you shouldn't fiddle with it, what makes you think that you know enough about cable derating factors, installation methods, disconnection times, volt drop etc to design and install a whole new circuit?
Im not a complete **** thats going to do something like this from just reading one post.
I have read other forums and guides on similar things. I have an idea of how u do it but want to know how, I have read this site aswell as many others and am just looking for more in detail advice.
So what "detailed advice" do you think you need?
And what will happen if you don't think to ask a question about something vital because you have absolutely no idea that that whole vital area even exists?
http://www.diydoctor.org.uk/projects/consumer_unit.htm
there is one for instance
And what does that instance say?
All cables and connections to the consumer unit must be checked and tested by a qualified electrician. Do not attempt removal or replacement unless you are you are qualified to Part P regulation standards."
Is it that you didn't like that advice, and hoped you'd get something you did like here?
If u cant help me I would appreciate ppl to refrain from posting.
I can't speak for the others (although I can make a pretty good guess), but I for one am not saying what I am in order to put you down, or appear superior or anything, and neither is anybody else.
If you but knew it we
are helping you.
I know u guys wana help and stop anything bad happening but i was blessed with a brain and i have my head screwed on am not going to rush str8 for my cu once i get a reply.
Thank you
Then use your brain to do 2 things:
1) Ponder why it is that the unanimous advice you've had is "don't do it"
2) Spend some time learning about the basics of circuit design, cable ratings, volt-drop, EFLI, disconnection times, MCB curves, installation methods, Ib<In<Iz etc, so that you come to
genuinely understand all the things you need to know to be able to design and install new circuits.
//www.diynot.com/forums/viewtopic.php?p=75416#75416
And while you're choosing books, and deciding where to buy them, you could do a lot worse than to start reading through this site:
http://www.tlc-direct.co.uk/Book/1.1.htm
