Adding another lamp to bathroom
3 May 2009
Aberdeen
I decided to add an extra fluorescent lamp in my upstairs ensuite bathroom. The bath had a single ceiling lamp with a switch outside the door. Few months ago, I got an electrician to install an extractor fan which is controlled by the same switch,
I thought I'd simply connect the new fluorescent light cable for cable to the points the electrician had wired the extractor fan.
So, I installed the flo. lamp, ran the cable upto the ceiling rose in the loft the fan is wired to. And then ran into confusion. I've got 3 cables (Live/Earth/Neutral) coming from the fluorescent fitting, but the electrician had 4 wires going to the extractor fan - Brown, Grey, Black and yellow/green!!!.
I need the same switch that controls this extractor fan to control the fluo. lamp (and also the original ceiling lamp). How woul I connect the 3 cables from the new lamp?.
Thanks for any advice.
Riz
That's because it's a timed-overrun fan, so as well as a switched live, like the light, it also has a permanent one to supply it until the run-on timer switches off.
To the live, neutral and earth that the existing light uses.
But if it is a ceiling rose you might find you're getting a bit tight with all those cables in there, and you should maybe consider using a junction box for the circuit & switch cables, and then cables coming out from there to the lights and the fan.
First you should learn how lighting circuits are wired though, or you're likely to get into a mess - study the info here: //www.diynot.com/wiki/electrics:lighting
If you can get access to the wiring from above it'll be easier, and you can use a normal 4-way junction box, or you might consider something like this:
which if necessary can be pushed through the hole in the ceiling.
