R
roberta1000
I've an elderly Ideal E-Type (1978) boiler with a pumped radiators and gravity hot water system. his makes the hot water rather too hot in winter when I turn the boiler thermostat up a bit to keep the house warm.
Are there any gotchas in fitting a cylinder thermostat and a zone valve to the gravity circuit?
If this is OK then I suppose I would need to wire it so that the boiler fires when either CH or Hot Water is wanted but the pump only runs on CH? That way the boiler wouldn't cycle when both Hot Water and CH are satisfied.
