- Joined
- 11 Jul 2007
- Messages
- 440
- Reaction score
- 3
- Country
In the Kitchen, there is slight bounce on the kitchen floor we want to tile.
The joists are the existing smaller ones from the 70's (I guess), with new 18mm tongue and groove chipboard flooring screwed and glued.
The old floor seemed ok, we took it up to make level after knocking through and now we have the bounce. I've managed to get into the very small crawl space (smaller that the rest of the house, most an army wriggle, then crawling).
My plan is add extra sleeper walls under the joists to support and eliminate the bounce.
As the space is so tight I was planning on two breeze blocks with a brick and some slate (with a DPM) sitting on the flat concrete oversite. If packed in tightly, would you say it is ok not to use mortar?
