Hi all,
Just like some info regarding the external wall iam decreasing the width of my window its currently 1600mm the new door will be 1200mm and will be left with a 200ish each side lintel is in place wider so no probs there, would it be a safe practice to add studwork onto the existing brickwork to make the width the correct size instead of brick work up im not convident of a line of bricks on top of each other not staggaered if that makes sence.
Thanks for your time gents
Lee
Lee
