Hi everyone.
I've been reading this site a lot on and off, and thought it is about time I signed up - so go easy on my 1st post. I suspect it is a bit controversial, but I'm a hardcore DIYer so wondered if you all might be able to help:
I've got a woodburner with a back boiler, connected to a direct hot water cylinder. It's a gravity system i.e. no pump. It was installed like that when I moved in.
The problem comes at this time of year when I have the fire on all day, it overheats the water and eventually boils it. The tank is vented into the header tank in the loft so it's not going to blow up, but I'd rather it didn't boil. I also don't want to melt the header tank which is plastic (!) What I would really like to do is add a radiator to shed some of the excess heat, just tee'd off the 28mm gravity pipes and also running on gravity.
My concern is that if I add a steel radiator, our hot water will turn brown. Obviously as it's a direct system I can't add inhibitor. Would using an aluminium radiator avoid the brown water, or would this corrode as well? Are there any radiators with some kind of internal coating out there that would not corrode? It would need to be a vertical radiator in order to get some height above the stove (I live in a bungalow).
I appreciate that my current system doesn't comply with regs, and to stay on the correct side of them I would (I think) need to convert to an indirect system. One day I'd like to do this, but money's tight and I really just want to stick in a radiator and leave it at that for now.
Any thoughts?
Thanks in advance for replies.
Sam
Any thoughts?
Sam
