Adding new window, where none currently exist
17 Dec 2018
Property is end of terrace
On the gable wall, there is a shared pathway between me and my neighbour (approx 1m wide)
Along the shared path, I want to add two new windows
1. On the ground floor
2. On the 1st floor
No windows currently exist here.
Can anyone advise on the rules around this please?
I did a bit of reading and am I right in saying that I do not need planning permission as long as the window is similar in appearance, obscure and the window is 1.7m above the floor level?
Neither ground- nor first floor window need p.p.
The only condition is that any first floor side-facing window is glazed in obscure glass and top opener min 1.7m above floor level.
Thank you.
So the ground floor windows do not need to be glazed?
and the their are no restriction regarding the height of the top opener?
As above, it might get draughty with no glass; there is no restriction on the size and position of the opener (unless it needs to be an escape window?).
Building regulations for fire spread at the boundary, as well as the structural work.
A valid point, but as the adjoinong space is a shared pathway unlikely to be built on, the relevant boundary would be 1m away, which gives the OP 5.6m2 of allowable window area.
And, yes, adequate lintels will be required,
(But OP seemed to be implying concern on possible planning rules rather than Building Regs?)
Might get a bit drafty
When we moved into our house two openings at one end of the kitchen had wooden shutters with no glazing. It was the old dairy and deliberately cold and well-ventilated. I put in normal (glazed) windows. :)
The shared alley is one metre wide, so 500mm to the boundary, and that is the issue, not the area of openings. In which case, the risk is flame/ hot smoke going out the window and over the boundary ... potentially up the wall and into the neighbouring roof or other route.
