Hey guys
First things first, Happy New Year to you all.
What I'd like to know is whether it's possible to tee off from the feed and return pipes of an existing radiator and add an additional radiator?
I'm guessing it's probably not advisable, but thought I'd better ask first.
When the central heating was fitted years ago, no radiator was fitted in the rear hall and because of this, it gets very chilly.
It actually feels like the heat from the lounge is being sucked out when a door is opened into the rear hall.
What I'm proposing is to add an equal tee compression fitting to both the feed and return pipes, connecting each to a separate radiator.
The additional radiator will be fitted on the other side of the wall from the existing kitchen radiator (new pipes will be fed through the wall to new radiator).
The current system is a Baxi Bermuda, running on 8mm microbore and currently supplying 6 radiators all with TRVs except the one the bottom of the stairs where the stat is located.
My guess is that it won't work properly and if this is the case, is there any other alternative that doesn't require major upheaval with regards lifting carpets, floorboards etc?
Cheers.
Cheers.
