Just moved into a flat that has a SD Thema F23e boiler. I know a lot of people don't like them so no need to labour that issue
I'm a bit confused about the heating aspect of things..
1) There is no room thermostat, however all except the bathroom radiator have thermostats. Now I understood that the boiler would run until all the temperatures are upto temp (it would detect that the water on the return was the same temperature as that on the flow, and shut down). However the pump in the boiler seems to run all the time, with the boiler firing up and down periodically (presumably when necessary). Is this correct?
2) I would rather fit a room thermostat so that the boiler will switch off when the main living area is upto temperature. This will also give me more flexibility as to when the boiler is running or not. Am I right in thinking that a normal thermostat will only require two wires from the boiler, which basically operate like a switch?
