- Joined
- 29 Nov 2008
- Messages
- 351
- Reaction score
- 29
- Country
I'm going to add 1 litre of sentinol x100 inhibitor to my system (9rads) as I have had problems with air accumulating and I suspect that there may be none in the system since we moved in recently. This is what i am going to do, please point out anything wrong or other suggestions/improvements:
- pour 1 litre x100 in f&e tank in loft
- drain approx 1 litre of existing water from a bleed valve on a ground floor rad to draw it into the system.
- run system for 3 hours or so to circulate
Is it possible to overdose a system if there be some in already?
Will I need to remove some water from f&e 1st or is above method ok?
While Im up there, what is the correct height for the vent pipe above the f&e water level?
