Hi guys, hopeing someone can help, last year i replaced the original Eurosec alarm system with the Accenta mini gen 4 as the codes were lost and i was unable to default it. New system works great apart from the RKP is located no where near the exit door we use. I like the look of the ADE simple set reader as an addition but after studying the manual on how to wire it up it has the 0v, 13v, sounds, comms and tamper terminals, but the simple set reader also has two terminals marked "relay". the manual suggests i should have two PTS terminals (i presume means Push To Set) on the gen 4 but i cant see this anywhere. The only thing i have noticed is that there is a terminal marked set next to the bellbox terminals but the manual says this is for latching detectors where the output becomes positive on correct set of the system and is removed by correct entry of the user code. Iv tried to contact honeywell but they will only talk to contractors. Sos that dragged on. Reguards ED
