Do i need to drain down fully to add a new toilet rad or could i close off all the rads and just cut into the flow and return pipes under the floor?
The house has a big void under the ground floor and i can easily crawl around and just need to T into the 15mm pipes under the floor. Any excess water is ok to drain out onto the sandy floor.
Or do i just drain down normally with a hose pipe ?
