Adding sockets & lights in extension (Part P Req?)
14 Jul 2008
Lancashire
I'm having an extension done soon and I obviously need to put sockets & lights in it. I've done quite a bit of electrical work in the past but haven't got Part P. :rolleyes:
I don't intend to put in another fuseway I was just going to splice into the relevant circuits and add the extra sockets & lights to the existing circuits. Non of this work is in a 'Special location'.
I seem to remember that adding extra sockets / lights is non-notifiable if not in 'Special locations'. Is that the case with an extension?
I await your words of wisdom....... ;)
Dave.
I think your LABC will want a certificate, why not seperate circuits?
Nice new CU with dual RCD!!
Either way I would ask your LABC what they want
Consumer unit isn't old. :(
Was just going to put the upstairs onto the existing and the same for downstairs. All cables are really easy to get at. :rolleyes:
Think you are correct though the BCO will want a cert. :mad:
Not sure the BCO will want certs. These are minor works as they are not in a special location and you are extending existing circuits. If I am correct it would be good practice to do a Minor Works Cert for safety reasons and retain this yourself. The work should be compliant with Part P but is not notifiable to the Local Authoity
Adding sockets or lights to existing circuits which doesn't involve work in a special location, a kitchen or work on a special installation is non notifable.
Was the electrical installation designed before 1/7/08?
Have you got Part A? Part B? Part C? Part D? Part E? Part F? Part G? Part H? Part J? Part K? Part L? Part M? Part N?
