I am dividing a room in to two and need to add 3 new sockets. I originally thought to tap in to each side of the existing ring with a Junction Box, daisy chain the 3 sockets from one of these junction boxes and then connect from the final socket to the junction box on the other side of the ring.
However things are not so simple. One side of the ring is accessible but the other is not with no slack in the cable. I read on another thread that I could run a spur of more than one socket if I used 4mm T&E. I always thought a spur was limited to a single socket. Is this viable? I have some 6mm cable I could use and the wire runs across a floor joist so no insulation/heating issues. Since I have one side of the ring accessible this would be the simplest option.
I also have a question re connectors. I've always used Junction Boxes in the past but can I use the maintenance free / lever type connectors in a Waco (or similar) box instead? This would be the first time I have done this so any advice / pointers to suitable products appreciated.
