I need to fit an external expansion vessel to Worcester Bosch R30 HE Combi. The MI suggests this should go on the CH return side of the boiler, but in this instance it would be a hell of a lot easier to put it on the flow. I note from the schematic that the pump and 3 way valve are on the return side...If I put the new expansion vessel on the flow side, if and when all the TRV's (and not one rad is without one) are closed, there is still an uninterrupted path from the heat exchanger to the expansion vessel. If I was to use the return, then the 3 way valve would disconnect the vessel when in DHW mode. So why should it go on the return side? is it to do with the extra pressure from the heat and flow direction of the boiler?
