I have just moved into a newly built house with a separate garage to which I want to add an external security light. The garage has one double socket with a single light switch taken off as a fused spur. I do not know at the moment if the supply into the garage is a spur off another circuit or is a dedicated circuit, I will check this when I get home.
I have read several other similar post on here and just want to check that if I wish to add additional lighting I can do so provided it runs through the same fuse as the existing lighting therefore preventing more than 5A ever being drawn by all of the lighting. Is this correct?
Secondly; rather than add an additional mounting box, it would be neat if I could find a double light switch with fuse to replace the existing single switch with fuse; do such things exist? A quick look online has not found any.
Thirdly; I assume this minor work is not notifiable?
Regards, James
Regards, James
