- Joined
- 11 Sep 2007
- Messages
- 827
- Reaction score
- 6
- Country
Here's a weird question.
The radiator in my lounge has the usual two vertical brackets on the wall that it hangs on. However the top screw on the left bracket has been partly ripped out and I'm looking for a way to 'glue' it back in without going to the big hassle of removing the radiator or the expense of calling in a plumber to do the job.
It's not a big deal as it is, the remaining screw in the left bracket and the bracket on the right are holding it in place okay, but I'd like to fix the minor in/out movement the radiator now has on the left side if I happen to pull on it for any reason.
This happened because for many year the top of the couch has been pushed up against the left side of the radiator, so over the years as the couch has had people sit in it there's been minor pressure applied to the radiator and the left bracket. I can see that the screw is now at and angle and is doing very little, a small piece of plaster is also breaking off.
So is there any kind of strong adhesive that I can apply to the area of the screw and bracket just to hold it firmer and prevent any movement?
I know this is far from an ideal solution but money is tight and I lack the skills to remove the radiator, etc.
